Hi, I’m looking at using the FEZ board on a new project.
But I need to know if the USB host port on domino can deal with multiple serial port devices, such as the FTDI FT4232H module. (ie. 4 x serial port via a single USB interface.)
[quote]In a commercial application, USB hubs are not a solution we can use.
[/quote]
Who said use a USB HUB in an enclosure? You can use a USB hub chip which is 2x2mm
[quote]Looks like its back the ICOP module and compact framework on CE6.
[/quote]
NETMF and CE can both do .NET but they are for complete different markets. There are places where CE6 fits best and others where NETMF is the right choice…but, a USB HUB is defiantly not a deciding factor here.
