Domino USB Detection Win7
i am a control systems engineer by trade,so one of the first things i tried was a different lead and then combined that with a different device to totally iliminate the lead and pc usb port. I have sent a email to ghi as requested, I havent probed about on the board with a meter as its new out the box and didn`t really see the need specially as the power led is on, and my meter is currently on my work desk :confused:
I forgot about the power LED :expressionless:
hello,
Maybe my post is useless if you solved already the issue.
Since vista MS incorporated a security that blocks a driver unsigned or sometimes for no obvious reason MS doesnโ€™t recognises the signature. If this happens you think your driver is installed but in fact MS stops it without message. In order to avoid that start a CMD with Admin privileges and run the following command bcdedit.exe /set nointegritychecks ON
. Reboot your PC, reinstall your driver and see if it works.
I had an issue like that with a usb RFID reader, everything looked fine but no way to use it until I did that.
Hope it helps
