I just want to confirm a pin out/wiring for a FEZ Dominio using the UEXT connector and an Analog ADXL345 accelerometer(Sparkfun breakout board) in SPI mode.
Thanks Joe. My column formatting got alittle screwed up.
When you refer to timing you’re talking about SPI transfer speed (the “100” in the code example I attached)? Or are there other timing parameters to be concerned with? The ADXL345 datasheet gives some idea on the SPI transfer speed relative to the sampling rate of the accelerometer. I’ve been throught the code sample I attached and have a good handle on each arguments.
