Does the WiFi RS21 Module use stock RS9110-N-11-21 ?
I have not seen the actual module but the photographs seem to indicate that the SST26VF016B Flash is missing on the WiFi RS21 Module.
I am trying to hook up a EMX and RS9110-N-11-22-01 no idea if it is compatible.
Sorry I meant ‘not populated’.
I never seem to understand the Redpine part numbers. The chipset (if you can call the metal can that) is the same but the connection modules have different numbers.
glx
December 1, 2016, 12:08pm
4
I have a board running with a RS9110-N-11-22-01, it works fine. Just make sure to run the firmware-update before using it the first time.
RoSchmi
December 1, 2016, 12:30pm
5
@ glx - Respekt, tolles Board.
@ glx - thank you !
did you download the firmware using a serial connection or through code from the G120 ?
glx
December 1, 2016, 1:03pm
7
Just run
before first use :).
[quote="RoSchmi"]@ glx - Respekt, tolles Bord. :clap:[/quote]
Got a bit further but I am hitting a block.
netif.UpdateFirmware();
Throws a HardwareTimeoutException
Changing the code as below completed the firmware update
netif.OperationTimeout = 99999;
However continuning with the below hangs or throws a HardwareTimeoutException
netif.Open()
Has anyone seen this before ?
@ Designer - Do any lights on the Wi-Fi module come on at any point? Can you see any response from the module on the SPI bus?
@ John - Yes the green led on the module does turn on.
I do not have the SPI trace right now. I will try to capture the entire SPI traffic to analyze.
I have the SPI bus connected over long wires. I am beginning to suspect impedance on the SPI SCK line.
Will update once I have more data.
