Does the SD reader support SD HC card?
does the SD reader support SD HC card ?
and what is the max size supported ?
It supports high capacity SD cards (over 4GB) and there is no limit on the size of the card supported
I can read 2gb cards without problem, but for 32gb the filenames returned from directory listings are garbled. Any suggestions what I might be doing wrong?
Thanks, Bernhard
There have been issues with certain brands of cards. I have several 4 and 8GB cards that work fine. 32GB though? Why do you need something so big?
I’ll get an 8gb card then. Which brands work?
App is logging. I don’t need 32gb if I get the data off the device regularly.
Thanks, Bernhard
