Using G400HDR as the Mainboard and adding WiFi_RS21 (Premium) results in
Module could not be Added:
A required library could not be found
I tried re-installing the latest GHI SDK to no avail.
If I use FEZRaptor WiFi_RS21 adds correctly. The Forum answered a previous issue with this module as requiring a Mainboard that uses the Premium Library.
So is the answer then that G400HDR can’t use the Premium Library or is it some other issue.
All G400 boards are premium.
HDR, Raptor are just different editions with different connectors.
So if something works with G400HDR it should also with raptor.
Unfortunately I can’t tell you why you get this error.
Does deleting HDR and add raptor in this project (not starting a new one) solve the issue?
As the G400HDR is not a Gadgeteer board, how are you trying to add the module to the program? Are you using a Gadgeteer framework or Console? Gadgeteer modules will not work on console programs without modification.
yes, deleting HDR and adding raptor allows Wifi_RS21 works
What I found is that GadgeteerHardware.XML in the G400HDR folder doesn’t contain entries for whereas the FEZRaptor configuration does contain entries for this section.
Where can I get a valid GadgeteerHardware.XML for G400HDR? Or can I simply add those library entries?
