The website is still being updated to handle the user privileges but I can share the new documentation and release notes with everyone
Documentation: (see USB Client)
http://www.ghielectronics.com/downloads/NETMF_Beta/Library/Index.html
Release Notes:
http://www.tinyclr.com/release-notes-beta/
This code emulates a USB mouse and moves it in a circle…This is how you can freak out your friends, wife and kids…put this program on FEZ and make the mouse movement run randomly every few minutes. Then plug FEZ behind someone’s computer. While they are using the computer, the mouse will start going in a circle on its own…“oh my god! it is a ghost!!!”
If you actually tried this trick on someone, please let us know how much fun you had
Have fun…
using GHIElectronics.NETMF.USBClient;
namespace USBClient_Example
// Check debug interface
if (Configuration.DebugInterface.GetCurrent() == Configuration.DebugInterface.Port.USB1)
throw new InvalidOperationException("Current debug interface is USB. It must be changed to something else before proceeding. Refer to your platform user manual to change the debug interface.");
// Start Mouse
USBC_Mouse mouse = USBClientController.StandardDevices.StartMouse();
// Move pointer in a swirl
const int ANGLE_STEP_SIZE = 7;
const int MIN_CIRCLE_DIAMETER = 50;
const int MAX_CIRCLE_DIAMETER = 300;
const int CIRCLE_DIAMETER_STEP_SIZE = 1;
int diameter = MIN_CIRCLE_DIAMETER;
int diameterIncrease = CIRCLE_DIAMETER_STEP_SIZE;
int angle = 0;
int factor;
// Check if connected to PC
if (USBClientController.GetState() != USBClientController.State.Running)
Debug.Print("Waiting to connect to PC...");
// Note Mouse X, Y are reported as change in position (relative position, not absolute)
factor = diameter * ANGLE_STEP_SIZE * (int)System.Math.PI / 180 / 2;
int dx = (-1 * factor * (int)Microsoft.SPOT.Math.Sin(angle) / 1000);
int dy = (factor * (int)Microsoft.SPOT.Math.Cos(angle) / 1000);
angle += ANGLE_STEP_SIZE;
diameter += diameterIncrease;
if (diameter >= MAX_CIRCLE_DIAMETER ||
diameter <= MIN_CIRCLE_DIAMETER
diameterIncrease *= -1;
// report mouse position
mouse.SendData(dx, dy, 0, USBC_Mouse.Buttons.BUTTON_NONE);
Thread.Sleep(10);
