This the output.
Found debugger!
Create TS.
Loading start at a0e00000, end a0e1383c
Assembly: mscorlib (4.2.0.0) Assembly: Microsoft.SPOT.Native (4.2.0.0) Assembly: Microsoft.SPOT.Security.PKCS11 (4.2
.0.0) Assembly: System.Security (4.2.0.0) Loading Deployment Assemblies.
Attaching deployed file.
Assembly: Microsoft.SPOT.IO (4.2.0.0) Attaching deployed file.
Assembly: Gadgeteer (2.42.0.0) Attaching deployed file.
Assembly: Gadgeteer.WebClient (2.42.0.0) Attaching deployed file.
Assembly: Microsoft.SPOT.Graphics (4.2.0.0) Attaching deployed file.
Assembly: Microsoft.SPOT.Hardware (4.2.0.0) Attaching deployed file.
Assembly: System.Http (4.2.0.0) Attaching deployed file.
Assembly: System (4.2.0.0) Attaching deployed file.
Assembly: Microsoft.SPOT.Net.Security (4.2.0.0) Attaching deployed file.
Assembly: serial communication with test daisylink (1.0.0.0) Attaching deployed file.
Assembly: Gadgeteer.WebServer (2.42.0.0) Attaching deployed file.
Assembly: GHI.Premium.Hardware (4.2.11.1) Attaching deployed file.
Assembly: GTM.GHIElectronics.Display_T35 (4.2.101.0) Attaching deployed file.
Assembly: Microsoft.SPOT.Touch (4.2.0.0) Attaching deployed file.
Assembly: System.Net.Security (4.2.0.0) Attaching deployed file.
Assembly: Microsoft.SPOT.TinyCore (4.2.0.0) Attaching deployed file.
Assembly: GHI.Premium.System (4.2.11.1) Attaching deployed file.
Assembly: Microsoft.SPOT.Net (4.2.0.0) Attaching deployed file.
Assembly: System.IO (4.2.0.0) Attaching deployed file.
Assembly: GHI.Premium.IO (4.2.11.1) Attaching deployed file.
Assembly: Microsoft.SPOT.Hardware.PWM (4.2.0.1) Attaching deployed file.
Assembly: Microsoft.SPOT.Hardware.SerialPort (4.2.0.0) Attaching deployed file.
Assembly: GHIElectronics.Gadgeteer.FEZSpider (4.2.101.0) Resolving.
GC: 1msec 39492 bytes used, 7300176 bytes available
Type 0F (STRING ): 24 bytes
Type 15 (FREEBLOCK ): 7300176 bytes
Type 17 (ASSEMBLY ): 34920 bytes
Type 1E (BINARY_BLOB_HEAD ): 4044 bytes
Type 28 (MEMORY_STREAM_HEAD ): 36 bytes
Type 29 (MEMORY_STREAM_DATA ): 396 bytes
GC: performing heap compactionâŚ
Ready.
âMicrosoft.SPOT.Debugger.CorDebug.dllâ (Gestito): caricato âC:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\mscorlib.dllâ, simboli caricati.
âMicrosoft.SPOT.Debugger.CorDebug.dllâ (Gestito): caricato âC:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Native.dllâ, simboli caricati.
âMicrosoft.SPOT.Debugger.CorDebug.dllâ (Gestito): caricato âC:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Hardware.dllâ, simboli caricati.
âMicrosoft.SPOT.Debugger.CorDebug.dllâ (Gestito): caricato âC:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Security.PKCS11.dllâ, simboli caricati.
âMicrosoft.SPOT.Debugger.CorDebug.dllâ (Gestito): caricato âC:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\System.Security.dllâ, simboli caricati.
âMicrosoft.SPOT.Debugger.CorDebug.dllâ (Gestito): caricato âC:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.IO.dllâ, simboli caricati.
âMicrosoft.SPOT.Debugger.CorDebug.dllâ (Gestito): caricato âC:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Hardware.PWM.dllâ, simboli caricati.
âMicrosoft.SPOT.Debugger.CorDebug.dllâ (Gestito): caricato âC:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Graphics.dllâ, simboli caricati.
âMicrosoft.SPOT.Debugger.CorDebug.dllâ (Gestito): caricato âC:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.TinyCore.dllâ, simboli caricati.
âMicrosoft.SPOT.Debugger.CorDebug.dllâ (Gestito): caricato âC:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Net.dllâ, simboli caricati.
âMicrosoft.SPOT.Debugger.CorDebug.dllâ (Gestito): caricato âC:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\System.IO.dllâ, simboli caricati.
âMicrosoft.SPOT.Debugger.CorDebug.dllâ (Gestito): caricato âC:\Program Files (x86)\Microsoft .NET Gadgeteer\Core\Assemblies.NET Micro Framework 4.2\le\Gadgeteer.dllâ, simboli caricati.
âMicrosoft.SPOT.Debugger.CorDebug.dllâ (Gestito): caricato âC:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\System.dllâ, simboli caricati.
âMicrosoft.SPOT.Debugger.CorDebug.dllâ (Gestito): caricato âC:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Net.Security.dllâ, simboli caricati.
âMicrosoft.SPOT.Debugger.CorDebug.dllâ (Gestito): caricato âC:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\System.Net.Security.dllâ, simboli caricati.
âMicrosoft.SPOT.Debugger.CorDebug.dllâ (Gestito): caricato âC:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\System.Http.dllâ, simboli caricati.
âMicrosoft.SPOT.Debugger.CorDebug.dllâ (Gestito): caricato âC:\Program Files (x86)\Microsoft .NET Gadgeteer\Core\Assemblies.NET Micro Framework 4.2\le\Gadgeteer.WebClient.dllâ, simboli caricati.
âMicrosoft.SPOT.Debugger.CorDebug.dllâ (Gestito): caricato âC:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Hardware.SerialPort.dllâ, simboli caricati.
âMicrosoft.SPOT.Debugger.CorDebug.dllâ (Gestito): caricato âC:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Touch.dllâ, simboli caricati.
âMicrosoft.SPOT.Debugger.CorDebug.dllâ (Gestito): caricato âC:\Program Files (x86)\GHI Electronics\GHI .NET Gadgeteer SDK\Modules\Display_T35\NETMF 4.2\le\GTM.GHIElectronics.Display_T35.dllâ, simboli caricati.
âMicrosoft.SPOT.Debugger.CorDebug.dllâ (Gestito): caricato âC:\Program Files (x86)\GHI Electronics\GHI Premium NETMF v4.2 SDK\Assemblies\le\GHI.Premium.System.dllâ
âMicrosoft.SPOT.Debugger.CorDebug.dllâ (Gestito): caricato âC:\Program Files (x86)\GHI Electronics\GHI Premium NETMF v4.2 SDK\Assemblies\le\GHI.Premium.IO.dllâ
âMicrosoft.SPOT.Debugger.CorDebug.dllâ (Gestito): caricato âC:\Program Files (x86)\GHI Electronics\GHI Premium NETMF v4.2 SDK\Assemblies\le\GHI.Premium.Hardware.dllâ
âMicrosoft.SPOT.Debugger.CorDebug.dllâ (Gestito): caricato âC:\Program Files (x86)\GHI Electronics\GHI .NET Gadgeteer SDK\Mainboards\FEZSpider\NETMF 4.2\le\GHIElectronics.Gadgeteer.FEZSpider.dllâ, simboli caricati.
âMicrosoft.SPOT.Debugger.CorDebug.dllâ (Gestito): caricato âJ:\Dev\c#\Gadgeteer\serial communication with test daisylink\serial communication with test daisylink\bin\Debug\le\serial communication with test daisylink.exeâ, simboli caricati.
âMicrosoft.SPOT.Debugger.CorDebug.dllâ (Gestito): caricato âC:\Program Files (x86)\Microsoft .NET Gadgeteer\Core\Assemblies.NET Micro Framework 4.2\le\Gadgeteer.WebServer.dllâ, simboli caricati.
Il thread ââ (0x2) è terminato con il codice 0 (0x0).
Using mainboard GHI Electronics FEZSpider version 1.0
Beginning chip reflashâŚ
Il thread ââ (0x4) è terminato con il codice 0 (0x0).
ConnectingâŚ
Connected!
ErasingâŚ
Erased!
Converting FileâŚ
Converted!
DownloadingâŚ
Il thread ââ (0x3) è terminato con il codice 0 (0x0).
Downloaded!
Board Flash Complete!
Il thread ââ (0x5) è terminato con il codice 0 (0x0).
Il programma â[24] Micro Framework application: Gestitoâ è terminato con il codice 0 (0x0).
I flashed the DL40 again. I removed the DL40.bin resource from the project and added that provided with the driver downloaded from codeshare, version 14.
