Hello, I would like to know if there is a way to distinguish between boards in runtime. I am usign either Cerbuino or Cerb40, and both give:
Mainboard.MainboardName = “GHI Electronics FEZCerbuinoBee”
Best regards
Eloy
Best regards
Eloy
@ epenciso - you can’t tell one from another.
I mean type of board, not serial nor mac.
Thank you. So, if there is no way, I will try something else.
Thank you again
Have a look at
Microsoft.SPOT.Hardware.SystemInfo.SystemID
It offers
OEM: the manufacturer ID (GHI in this case)
SKU: Stock keeping Unit
Model: This is what you are looking for.
5 = EMX
8 = G120
Don’t know the others
In combination with the OEM ID it should be unique.
Edit: Sorry, didn’t read your post carefully enough, I assume any Cerb will have the same Model id here.
Thank you for the info Reinhard, it is usefull to know it in any case.
@ epenciso -
I do not know if it will work with your board but try the following and seen if if fits your needs… Good luck!
//Program is the >public partial class 'Program' < class of your program
Debug.Print("Mainboard " + Program.Mainboard.MainboardName);
Debug.Print("Version " + Program.Mainboard.MainboardVersion);
Debug.Print("Model: " + Microsoft.SPOT.Hardware.SystemInfo.SystemID.Model.ToString());
Debug.Print("OEM: " + Microsoft.SPOT.Hardware.SystemInfo.SystemID.OEM.ToString());
Debug.Print("SKU: " + Microsoft.SPOT.Hardware.SystemInfo.SystemID.SKU.ToString());
