I got a Distance US3 sensor module with FEZ spider mainboard (firmware 4.2.11.1) a few weeks ago from Mouser. After deployment, the returned distance seems to be incorrect as its value returns between 14-17 in range even if I move the sensor in and out. What wrong and could you please help me finding out the issue?
I’ve moved around in any direction to measure distance but the sensor did provide incorrect result, Here are the test scenarios
case | actual value | returned value
1.sensor to so close object | 5 cm | 14 cm
2.sensor to cabinet | 50 cm | 17 cm
3.sensor to ceiling | 150-200 cm | 17 cm
4.sensor to floor | 100 cm | 17 cm
@ Phisarn I have a number of these modules so I’ll setup some tests with them tomorrow and post my results. I was thinking of using them for a snow pack experiment, but they only seem to have 1 cm resolution and I was needing 1 mm resolution, but I’m sure I’ll find other uses for them, but for now I’ll setup a test and see how they do.
How many measurements are you telling GetDistanceInCentimeters to take? Does it ever return SENSOR_ERROR (-1)? Could you post a minimal example that reproduces the error?
using System.IO;
using GT = Gadgeteer;
namespace DistanceTest2
public partial class Program
private readonly Font _font = Resources.GetFont(Resources.FontResources.small);
private string _distance;
private void ProgramStarted()
capTouch.ButtonPressed += capTouch_ButtonPressed;
button.ButtonPressed += button_ButtonPressed;
private void button_ButtonPressed(Button sender, Button.ButtonState state)
double distance = 0;
Mainboard.SetDebugLED(true);
if (_distance.Length > 0)
distance = Convert.ToDouble(_distance);
oledDisplay.SimpleGraphics.Clear();
oledDisplay.SimpleGraphics.DisplayText(distance.ToString(), _font, GT.Color.White, 0, 0);
int distance1 = distance_US3.GetDistanceInCentimeters(10);
oledDisplay.SimpleGraphics.DisplayText("1. " + distance1, _font, GT.Color.Yellow, 0, 15);
int distance2 = distance_US32.GetDistanceInCentimeters(10);
oledDisplay.SimpleGraphics.DisplayText("2. " + distance2, _font, GT.Color.Orange, 0, 30);
int distance3 = distance_US33.GetDistanceInCentimeters(10);
oledDisplay.SimpleGraphics.DisplayText("3. " + distance3, _font, GT.Color.Red, 0, 45);
if (sdCard.IsCardMounted)
try
FileStream fs = sdCard.GetStorageDevice().OpenWrite("Data.txt");
var sw = new StreamWriter(fs);
sw.WriteLine(distance1 + ";" + distance1 + ";" + distance2 + ";" + distance3);
sw.Flush();
sw.Close();
fs.Close();
catch (Exception ex)
Debug.Print("Message: " + ex.Message + " Inner Exception: " + ex.InnerException);
Mainboard.SetDebugLED(false);
private void capTouch_ButtonPressed(Gadgeteer.Modules.GMod.CapTouch sender, int button,
Gadgeteer.Modules.GMod.CapTouch.ButtonState state)
switch (button)
case 11:
_distance = string.Empty;
break;
case 9:
_distance = _distance + ".";
break;
case 10:
_distance = _distance + "0";
break;
default:
_distance = _distance + (button + 1);
break;
My initial tests are making me want to do more tests as the results weren’t as good as I hoped as anything under 9" was reporting as 14 cm and I thought the sensor was 2cm to 400cm in range, so more testing later.
Hello,
i have a problem like that.
Sensor Distance US 3 connected to Cerbot 1.3 return always distance between 4 to 50 cm.
When i connect the same sensor to Spider 1.0, sensor return distance up to 50 cm (200 cm for ex).
Code is the same with 2 projects :
new Thread(CheckDistance).Start();
public void CheckDistance()
int j;
distance_US3.AcceptableErrorRate = 2;
j = distance_US3.GetDistanceInCentimeters(5);
Thread.Sleep(100);
if (j == distance_US3.SENSOR_ERROR)
Debug.Print("Sensor errror");
Debug.Print("D=" + j);
Why i can’t have distance up to 50 cm with sensor connected to Cerbot ?
