Anybody making a distance module with 1mm accuracy? IR, Ultrasonic, whatever?
Is on my ‘Modules to Build’ list…planned to use the VCNL4000 Sensor. Don’t know if it’s that accurate
I was looking for something with a range of about 1 or maybe 2 meters (was trying to make a snow pack monitor).
What would be cool is a module for IR Distance, where you could plug in any suitable sensor. For example a module that you could plug any of GP2Y0A02YK, P2Y0A710YK0F, GP2D120XJ00F, etc. It would be like the gas sensor in that you could plug any one of a number of IR sensors into it depending on your needs.
I’ve combed every post on the forum with the terms +distance and +sensor in them. I figured this would be something that would have been worked out a long time ago. Maybe not.
I need a small sensor that can measure from about 6" to about 18". It only need to be accurate to about a 1/2".
The problem is that I have a passive IR device in place already and I’m afraid that some of the sensors mentioned in the posts will interfere. That won’t work.
I bought the one from GHI and didn’t realize until I opened the package that it was really pretty large. I am trying to put this into a hand held device, so size is pretty important. Also, since it could be dropped easily, this sensor needs to be fairly sturdy.
I can’t seem to find any recent work on this.
Anybody know anything new?
TIA
OK, maybe I jumped a little too quickly.
I found this: MB1020 LV-MaxSonar-EZ2 | MaxBotix Inc.
Anyone have any experience with the MaxBotix line?
Sorry @ willy I don’t have any experience with that particular device.
What I was getting at is what you found, that distancing options are rather thin which really doesn’t make any sense given a lot of these devices work exactly the same and even have the same output and power requirements so having a base module where you could plug in different range devices only makes sense and fills a huge need area for Gadgeteer.
Seems I have an impulse control problem.
Amazon prime + 3.99 and I’ll get one later today.
I’ll let you know.
thanks.
