Is there a way to set wifi module off or led off on FEZ board ?
Do you mean disable the LEDs that are connected to the wifi module? I think you can disable only the “blinking” LED. It has been a while since I looked at the datasheet.
The best place to see what the module is capable of is through the module’s datasheet.
Thanks for tips. I’ll dive into datasheet, but I was hoping it can be done with a pin or two
But you like challenges
When not using Wifi, I can do:
var cont = GpioController.GetDefault();
ResetWifi = cont.OpenPin(Pins.FEZ.GpioPin.WiFiReset);
ResetWifi.SetDriveMode(GpioPinDriveMode.Output);
ResetWifi.Write(GpioPinValue.Low);
I knew you will find a way
With use of wifi, it can be done by:
public void DisableLed()
if (!running) throw new Exception("Must be called after TurnOn() function");
SetBlinkLed(false);
SetGpioOutput(13, Direction.Output);
SetGpioOutput(14, Direction.Output);
protected enum Direction { Input, Output }
protected void SetBlinkLed(bool active)
var cmd = this.GetCommand()
.AddParameter("blink_led")
.AddParameter(active ? "1" : "0")
.Finalize(SPWF04SxCommandIds.SCFG);
this.EnqueueCommand(cmd);
cmd.ReadBuffer();
this.FinishCommand(cmd);
protected void SetGpioOutput(int number, Direction dir, bool active = false)
.AddParameter(number.ToString())
.AddParameter(dir == Direction.Output ? "out" : "in")
.Finalize(SPWF04SxCommandIds.GPIOC);
cmd.ReadBuffer();
.Finalize(SPWF04SxCommandIds.GPIOW);
cmd.ReadBuffer();
