hi,
can someone explain to me how you use the command DigitalOutput?
Use a gadgeteer MOUNTANEER eth.
I tried to use the following code:
GT.Interfaces.DigitalOutput out1;
GT.Socket GT.Socket.GetSocket socket = (4, true, null, null);
out1 = new GT.Interfaces.DigitalOutput (socket, GT.Socket.Pin.Three, true, null);
out1.Write (true);
but it does not work, I get:
Create TS.
Loading start at 8054110, end 8066fcc
Assembly: mscorlib (4.2.0.0) Assembly: Microsoft.SPOT.Native (4.2.0.0) Assembly: Microsoft.SPOT.Hardware (4.2.0.0)
Assembly: Microsoft.SPOT.Hardware.PWM (4.2.0.1) Assembly: Microsoft.SPOT.Hardware.SerialPort (4.2.0.0)
Assembly: Microsoft.SPOT.Net (4.2.0.0) Assembly: System (4.2.0.0) Loading Deployment Assemblies.
Attaching deployed file.
Assembly: MFConsoleApplication1 (1.0.0.0) Attaching files deployed.
Assembly: Microsoft.SPOT.IO (4.2.0.0) Attaching files deployed.
Assembly: Microsoft.SPOT.TinyCore (4.2.0.0) Attaching files deployed.
Assembly: Microsoft.SPOT.Graphics (4.2.0.0) Attaching files deployed.
Assembly: Mountaineer.Netmf.Hardware (1.0.0.0) Attaching files deployed.
Assembly: System.IO (4.2.0.0) Attaching files deployed.
Assembly: Gadgeteer (2.42.0.0) Resolving.
Resolve: unknown type: Microsoft.SPOT.Touch.TouchGestureEventArgs
Error: ff000000
The program '[4] Micro Framework application: Managed' has exited with code 0 (0x0).
Waiting for debug commands ...
