I have one G400 Beta Test Kits and I am having difficulty running the TinyBooter Update Procedure. I connect the board directly to my Windows XP computer USB port and I see
"Debuggable .Net Micro Framework Device -> GHT .NET Micro Framework USB Debugging Interface show up in Device Manager.
If I ground PA11 when I power-up board ( only holding ground for ~1.5 seconds) I do not see any change in that I still see the GHI .NET Micro Framework USB Debuuging Interface show up and nothing else new in Device Manager.
If I run FEZ Config v1.3 G400_G400 shows up. I then connect to it okay.
I can see device capabilities under Advanced . Most items shows as Version : 4.2.0.0
If I push the Device Version button it takes about 30 seconds and reports the following:
Loader (TinyBooter) Version:
Firmware (TinyCLR) Version: 4.2.0.0
and then pops up a window reporting " No response from device" with an OK button.
Any ideas what I am doing wrong or things I should try?
