I am using g400 with latest firmware and framework.
sometimes after restarting device without any powerdown, the dhcpclient does not get a valid IP from the dhcp server.
Any tries using mf download interface, firmwaredownload by usb won’t work in this situation.
I powered down the system, restarted … and got a correct ip submitted by the dhcp server.
In my application i use a lot of tcp connections and the restart in general is done by Reboot Command.
the system includes a debugging interface, therefore i can easy inspect the current controller state.
I enumerate and check the current ip in interval.
as I mentioned, sometimes the dhcp-ip is not assigned and the only way to get an ip is to power down and restart the whole device.
a software reboot ist not sufficient.
