DfuSe Won't run under WIndows 8
Hello guys,
in order to update the tinyloader of the Cerbuino Bee I’d have to use DFUSE, which I installed from the supplied installer located under GHI Folder. Now when I try to run it I get the error below: I tried both x86 and x64 same error…
can anyone point me to how to resolve this?
thanks.
this version works:
http://code.google.com/p/dsonano/downloads/detail?name=um0412.zip
not sure why??? it’s 3.0
@ Jay Jay - What version of Windows 8 do you have? STDFU Tester installs and functions on my Win8 x64 box.
Tried both versions, same error…
I have x64… Windows 8.1
@ Jay Jay - Ah, I have not yet updated to 8.1. I will do this and retest the application
Verified working on Windows 8.1 64bit
Interesting, I’m not sure what I’m missing…
I’ll try it again…
But 3.0 worked fine for me, so i wonder what 3.1 brings and if it is worth the trouble…
I would say that as long as you’re able to flash the firmware without trouble, and you dont need a specific change made in 3.0.1, then my opinion would be that it’s not worth it :slight_smile:
