UV Sensor driver for 4.2 and 4.1 is now available at http://gadgeteerdfrobot.codeplex.com source code is also available.
If someone has a UV Meter they could compare the UV Index of the UV Sensor (which is calculated from voltage), please let me know how close I am.
Of course suggestions, comments and or general abuse welcomed.
The UV Sensor is a pretty simple sensor, and I think the next one I’ll go after is the SD2403 Real -Time clock Module ( SD2403 Real -Time clock Module(Gadgeteer Arduino Compatible) )
Think I need to put some time into putting all the modules into a nice single installer, any suggestions?
