Since it is impossible to use WPF in NETMF, I constructed two projects under same solution - one for the hardware and one is pure WPF.
I am trying to show data from the HW project in the WPF project (something like putting the accelerometer readings in a textbox) but I cannot transfer data between the projects. Referencing doesn’t work because an error pops “the two projects are of differetn families” (duh!).
I’d like to show values from the hardware on my pc using simple wpf controls. Any ideas?
like Eric said you will need an interface for the two DIFFERENT Worlds to talk …
So either ETHERNET, or RS232…
please look for Web Server Examples on the wiki also you can check back this Forum i just saw a post of a user who was successful in communicating with his board through the USB port.
Data communication between the HW and any other application should have a dedicated channel, and cannot use the connection established for the deployment and debugging.
The (only one) USB cable connected to the setup, providing power and communication to the MSVS cannot ve used for this
If this is right, I’m screwed: Just in order to check values in the developing process, I have to set up a Wireless Ethernet or bluetooth communication
If I’m wrong, and the existing USB connection can ALSO be used to communicate with other applications, I’d love a pointer to an example.
please do a search in this forum your questions have been answered with examples…
you can switch to serial debugging… and use the USB for communication…
