I have been developing all week on a project with a custom board and a G400-D and now I cannot deploy and it just hangs and the attached window appears.
The following appears in the Output window during the partial starting.
DEPLOYMENT seems ok
Looking for a device on transport 'USB'
Starting device deployment...
Iteration 0
Opening port \\?\usb#vid_1b9f&pid_0102#0000000001#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
Attaching debugger engine...
... debugger engine attached!
Querying device assemblies...
Found Assembly mscorlib 4.3.1.0
Found Assembly Microsoft.SPOT.Native 4.3.1.0
Found Assembly Microsoft.SPOT.Security.PKCS11 4.3.1.0
Found Assembly System.Security 4.3.1.0
Found Assembly Microsoft.SPOT.Hardware 4.3.1.0
Found Assembly Microsoft.SPOT.Graphics 4.3.1.0
Found Assembly Microsoft.SPOT.TinyCore 4.3.1.0
Found Assembly Microsoft.SPOT.IO 4.3.1.0
Found Assembly System.IO 4.3.1.0
Found Assembly Microsoft.SPOT.Hardware.Usb 4.3.1.0
Found Assembly Microsoft.SPOT.Hardware.SerialPort 4.3.1.0
Found Assembly Microsoft.SPOT.Touch 4.3.1.0
Found Assembly Microsoft.SPOT.Ink 4.3.1.0
Found Assembly Microsoft.SPOT.Hardware.PWM 4.3.1.0
Found Assembly Gadgeteer 2.43.1.0
Found Assembly GHI.Hardware 4.3.7.10
Found Assembly Microsoft.SPOT.Net.Security 4.3.1.0
Found Assembly GHI.Glide 4.3.0.2
Found Assembly System 4.3.1.0
Found Assembly System.Http 4.3.1.0
Found Assembly System.Xml 4.3.1.0
Found Assembly System.Net.Security 4.3.1.0
Found Assembly GHI.Usb 4.3.7.10
Found Assembly GHI.Pins 4.3.7.10
Found Assembly Microsoft.SPOT.Net 4.3.1.0
Found Assembly WeatherSMS 1.0.0.0
Found Assembly GHI.Networking 4.3.7.10
Adding pe file C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Net.pe to deployment bundle
Adding pe file C:\Program Files (x86)\GHI Electronics\NETMF v4.3 SDK\Libraries\le\ghi.hardware.pe to deployment bundle
Adding pe file C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Net.Security.pe to deployment bundle
Adding pe file C:\Users\Dave McLaughlin\documents\visual studio 2013\Projects\Glide4.3\Glide\bin\Release\le\ghi.glide.pe to deployment bundle
Adding pe file C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\System.pe to deployment bundle
Adding pe file C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\System.Http.pe to deployment bundle
Adding pe file C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\System.Xml.pe to deployment bundle
Adding pe file C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\System.Net.Security.pe to deployment bundle
Adding pe file C:\Program Files (x86)\GHI Electronics\NETMF v4.3 SDK\Libraries\le\ghi.usb.pe to deployment bundle
Adding pe file C:\Program Files (x86)\GHI Electronics\NETMF v4.3 SDK\Libraries\le\ghi.pins.pe to deployment bundle
Adding pe file C:\Users\Dave McLaughlin\documents\visual studio 2013\Projects\WeatherSMS\WeatherSMS\bin\Debug\le\WeatherSMS.pe to deployment bundle
Adding pe file C:\Program Files (x86)\GHI Electronics\NETMF v4.3 SDK\Libraries\le\ghi.networking.pe to deployment bundle
Attempting deployment...
Incrementally deploying assemblies to device
Deploying assemblies for a total size of 1032204 bytes
Assemblies successfully deployed to device.
But running hangs and the attached shows up when I click on the output window.
Found debugger!
Create TS.
Loading start at 202dd578, end 2030ca0c
Assembly: mscorlib (4.3.1.0) Assembly: Microsoft.SPOT.Native (4.3.1.0) Assembly: Microsoft.SPOT.Security.PKCS11 (4.3
.1.0) Assembly: System.Security (4.3.1.0) Assembly: Microsoft.SPOT.Hardware (4.3.1.0)
Assembly: Microsoft.SPOT.Graphics (4.3.1.0) Assembly: Microsoft.SPOT.TinyCore (4.3.1.0)
Assembly: Microsoft.SPOT.IO (4.3.1.0) Assembly: System.IO (4.3.1.0) Assembly: Microsoft.SPOT.Hardware.Usb (4.3.1.0)
Assembly: Microsoft.SPOT.Hardware.SerialPort (4.3.1.0) Assembly: Microsoft.SPOT.Touch (4.3.1.0)
Assembly: Microsoft.SPOT.Ink (4.3.1.0) Assembly: Microsoft.SPOT.Hardware.PWM (4.3.1.0)
Attaching deployed file.
Assembly: Microsoft.SPOT.Net (4.3.1.0) Attaching deployed file.
Assembly: GHI.Hardware (4.3.7.10) Attaching deployed file.
Assembly: Microsoft.SPOT.Net.Security (4.3.1.0) Attaching deployed file.
Assembly: GHI.Glide (4.3.0.2) Attaching deployed file.
Assembly: System (4.3.1.0) Attaching deployed file.
Assembly: System.Http (4.3.1.0) Attaching deployed file.
Assembly: System.Xml (4.3.1.0) Attaching deployed file.
Assembly: System.Net.Security (4.3.1.0) Attaching deployed file.
Assembly: GHI.Usb (4.3.7.10) Attaching deployed file.
Assembly: GHI.Pins (4.3.7.10) Attaching deployed file.
Assembly: WeatherSMS (1.0.0.0) Attaching deployed file.
Assembly: GHI.Networking (4.3.7.10) Resolving.
GC: 1msec 1213728 bytes used, 65892036 bytes available
Type 0F (STRING ): 24 bytes
Type 15 (FREEBLOCK ): 65892036 bytes
Type 17 (ASSEMBLY ): 44652 bytes
Type 1E (BINARY_BLOB_HEAD ): 1168980 bytes
GC: performing heap compaction...
Ready.
'Microsoft.SPOT.Debugger.CorDebug.12.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Native.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.12.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Hardware.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.12.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Security.PKCS11.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.12.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\System.Security.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.12.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Graphics.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.12.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.TinyCore.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.12.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.IO.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.12.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\System.IO.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.12.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Hardware.Usb.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.12.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Hardware.SerialPort.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.12.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Touch.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.12.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Ink.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.12.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Hardware.PWM.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.12.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Net.dll', Symbols loaded.
I’ve tried clean and it still won’t run. The only change last night to the code was to add 5 jpg files to the resources and to add code to display them.
