I’m getting more and more confident in my new Panda and would like to start working on easing deployment for production usage.
I have googled quite a bit, but I haven’t been able to tell if it is possible to deploy an application without making a custom firmware?
From the USBizi manual I gathered that the GHI Bootloader can load managed code, but from my understanding this is not the output format of my VS compilation. Therefore I cannot modify the MAC address in this during deployment.
I am using the Ethernet Shield which means I need to put in a MAC address, and thus my deployment scenario includes that I need to compile the .NET MF application.
Therefore, what I would like to achieve is a utility which can
Plug in MAC address to my C# source code
Compile the .NET MF application
Deploy the application
How would you go about this? What is the best practice?
Perhaps I could also include an initial step for updating the device to GHI’s latest firmware version.
You wouldn’t create an appp to compile, this is too much work. Just compile from VS then use the GHI loader on USBizi to create a “master copy” of your firmware. From there you will have a file that you can load at production. IT is loaded using XMODEM protocol which is very common and easy to implement.
But how would I go about specifying the MAC address, so that each device has a unique address?
I don’t believe I have other choices than specifying it in my source code or adding a SD card to the device which could store the address. I would much prefer the former in that case.
Isn’t the MAC address supposed to be in my compiled application, to be passed onto the Dhcp.EnableDhcp method?
Do I have an alternative to this?
EDIT:
Oh perhaps I can set the MAC permanently using MFDeploy?
If this is the case, I simply deploy once using VS and then copy it to other devices. Probably I could use MFDeploy’s API to set the MAC address afterwards then.
You can set the MAC address using MFDeploy but this is only available on boards that have integrated Ethernet (like Cobra). When you are using an Ethernet module like Wiznet than you need to store the MAC address and initialize the module with it.
Yes, if you write an application to talk to teraterm that writes to InternalFlashStorage.
How about this:
[ol]You flash your application to the board.
Your program starts
It looks in InternalFlashStorage for MAC adderss
It find MAC and continues normally OR if it doesn’t frin MAC then it connects via xmodem to get MAC and stores it in InternalFlashStorage[/ol]
That way it will start up in “config mode” if it isn’t configured yet, or it will run as final product once it gets it’s config…
