Deploy to FEZ Stick but not to SC20100S Dev Board
My App and the demo App will deploy and run on my FEZ Stick but not on my SC20100S Dev Board. That last statement ‘There were not enough space totaling 0 bytes found for assembly: 186776’ may be the cause?
Here is the Output Window:
Looking for a device on transport ‘USB’.
Found device port ‘USB’ with ID ‘78923039-484f-4483-8497-20beda7f6c8b’ for transport ‘Usb’.
Starting device deployment.
Attempting to connect to device ‘USB:SC20100’: iteration 0.
Opening port ‘\?\usb#vid_1b9f&pid_5010#9&24bd5723&0&2#{c13bcfe9-5e84-4187-9baa-45597ffcbb6f}’.
Attaching debugger engine.
Debugger engine attached.
Generating device specific assemblies.
  • BlueFire v5.11000.9419.25876 with size 80,372 bytes at ‘C:\Development\BlueFire\Adapter\BlueFire 5\BlueFire 5.1\bin\Debug\pe\BlueFire.pe’.
  • mscorlib v2.3.0.1000 with size 72,556 bytes at ‘C:\Development\BlueFire\Adapter\BlueFire 5\BlueFire 5.1\bin\Debug\pe\mscorlib.pe’.
  • GHIElectronics.TinyCLR.Devices.Can v2.3.0.1000 with size 8,864 bytes at ‘C:\Development\BlueFire\Adapter\BlueFire 5\BlueFire 5.1\bin\Debug\pe\GHIElectronics.TinyCLR.Devices.Can.pe’.
  • GHIElectronics.TinyCLR.Devices.Gpio v2.3.0.1000 with size 4,880 bytes at ‘C:\Development\BlueFire\Adapter\BlueFire 5\BlueFire 5.1\bin\Debug\pe\GHIElectronics.TinyCLR.Devices.Gpio.pe’.
  • GHIElectronics.TinyCLR.Devices.Pwm v2.3.0.1000 with size 3,012 bytes at ‘C:\Development\BlueFire\Adapter\BlueFire 5\BlueFire 5.1\bin\Debug\pe\GHIElectronics.TinyCLR.Devices.Pwm.pe’.
  • GHIElectronics.TinyCLR.Devices.SecureStorage v2.3.0.1000 with size 1,228 bytes at ‘C:\Development\BlueFire\Adapter\BlueFire 5\BlueFire 5.1\bin\Debug\pe\GHIElectronics.TinyCLR.Devices.SecureStorage.pe’.
  • GHIElectronics.TinyCLR.Devices.Uart v2.3.0.1000 with size 8,012 bytes at ‘C:\Development\BlueFire\Adapter\BlueFire 5\BlueFire 5.1\bin\Debug\pe\GHIElectronics.TinyCLR.Devices.Uart.pe’.
  • GHIElectronics.TinyCLR.Devices.Watchdog v2.3.0.1000 with size 1,652 bytes at ‘C:\Development\BlueFire\Adapter\BlueFire 5\BlueFire 5.1\bin\Debug\pe\GHIElectronics.TinyCLR.Devices.Watchdog.pe’.
  • GHIElectronics.TinyCLR.Native v2.3.0.1000 with size 6,200 bytes at ‘C:\Development\BlueFire\Adapter\BlueFire 5\BlueFire 5.1\bin\Debug\pe\GHIElectronics.TinyCLR.Native.pe’.
    Total deployment size is 186,776 bytes.
    Incrementally deploying assemblies to the device:
    There were not enough space totaling 0 bytes found for assembly: 186776.
    Assemblies not successfully deployed to the device.
    Deployment to the device was not successful.
Fixed it by updating the SC20100S firmware.
