I’m seeing the following error message during deployment.
------ Deploy started: Project: FEZ Panda Grove LCD, Configuration: Debug Any CPU ------
An error has occurred: please check your hardware.
Object reference not set to an instance of an object.
Source: Microsoft.SPOT.Debugger.CorDebug
Stack :
at Microsoft.SPOT.Debugger.VsProjectFlavorCfg.Deploy() in c:\depot\current\CLIENT_V4_1\Framework\CorDebug\VsProjectFlavorCfg.cs:line 893
at Microsoft.SPOT.Debugger.VsProjectFlavorCfg.<Microsoft.VisualStudio.Shell.Interop.IVsDeployableProjectCfg.StartDeploy>b__0() in c:\depot\current\CLIENT_V4_1\Framework\CorDebug\VsProjectFlavorCfg.cs:line 634
========== Deploy: 0 succeeded, 1 failed, 0 skipped ==========
Here’s some background information.
I have a collection of drivers that we are trying to share with coworkers. We are trying to share everything via a single .DLL file. So, our VS project is set to build the code as a class library. We are hoping that others can simply “Add Reference” to that DLL, and use the drivers.
Everything works great for me, on my PC. I can create a new project, add a reference to the DLL, and use the driver code as I would expect.
However, when other people try to do the same thing (after copying the DLL to their own PC), they run into the error shown above. I’m wondering if it has something to do with permissions/security. ???
Any ideas?
