I’m having the same problem following the almost same steps that John mentioned.
How can I get around this.
Follows the settings of my environment:
Hardware:
Fez Spider Mainboard 1.0
Button 1.4
Camera 1.1
Display T35 1.3
SDCard 1.4
USBClient DP 1.3 (Only Power Supply)
SanDisk MicroSDHC 4Gb class 2
SanDisk MicorSDHC Adapter
Fez Config:
Loader (TinyBooter) version information:
4.2.11.1 on this computer.
4.2.11.1 on this device
Firmware (TinyCLR) version information:
4.2.11.1 on this device.
Software
VS2012
MicroFrameworkSDK NETMF SDK 4.3 (RTM) for VS2012
MicroFrameworkSDK NETMF SDK 4.2 (RTM QFE2) for VS2010
GHI NETMF v4.2 and Gadgeteer Package 2013 R3
My screen is showing the following:
EMX
Version : 4.2.11.1
Debug : USB1
LCD : 320X240
But soon after starting Degug an error is shown :
# # # Exception System.NullReferenceException - CLR_E_NULL_REFERENCE (4) # # #
# # # Message :
# # # Microsoft.SPOT.Application :: OnEvent [ IP : 0090 ] # # #
# # # Microsoft.SPOT.EventSink :: ProcessEvent [ IP : 0023 ] # # #
# # # Microsoft.SPOT.EventSink :: EventDispatchCallback [ IP : 0014 ] # # #
A first chance exception of type ’ System.NullReferenceException’ occurred in Microsoft.SPOT.TinyCore.dll
An unhandled exception of type ’ System.NullReferenceException’ occurred in Microsoft.SPOT.TinyCore.dll
This is the beginning of the debug output :
[em]Found debugger !
Create TS .
A0e00000 loading at start , end a0e1383c
Assembly: mscorlib ( 4.2.0.0 ) Assembly: Microsoft.SPOT.Native ( 4.2.0.0 ) Assembly: Microsoft.SPOT.Security.PKCS11 ( 4.2
.0.0 ) Assembly: System.Security ( 4.2.0.0 ) Loading Deployment Assemblies .
Attaching file deployed .
Assembly: Microsoft.SPOT.IO ( 4.2.0.0 ) Attaching deployed file .
Assembly: GHI.Premium.IO ( 4.2.11.1 ) Attaching deployed file .
Assembly: Microsoft.SPOT.Graphics ( 4.2.0.0 ) Attaching deployed file .
Assembly: GHI.Premium.SQLite ( 4.2.11.1 ) Attaching deployed file .
Assembly: GTM.GHIElectronics.Camera ( 4.2.101.0 ) Attaching deployed file .
Assembly: GHI.Premium.USBHost ( 4.2.11.1 ) Attaching deployed file .
Assembly: GTM.GHIElectronics.SDCard ( 4.2.101.0 ) Attaching deployed file .
Assembly: Microsoft.SPOT.Hardware ( 4.2.0.0 ) Attaching deployed file .
Assembly: GHI.Premium.System ( 4.2.11.1 ) Attaching deployed file .
Assembly: GTM.GHIElectronics.Display_T35 ( 4.2.101.0 ) Attaching deployed file .
Assembly: Microsoft.SPOT.Touch ( 4.2.0.0 ) Attaching deployed file .
Assembly: GTM.GHIElectronics.UsbClientDP ( 4.2.101.0 ) Attaching deployed file .
Assembly: Gadgeteer ( 2.42.0.0 ) Attaching deployed file .
Assembly: GTM.GHIElectronics.Button ( 4.2.101.0 ) Attaching deployed file .
Assembly: GadgeteerApp2 ( 1.0.0.0 ) Attaching deployed file .
Assembly: System.IO ( 4.2.0.0 ) Attaching deployed file .
Assembly: Microsoft.SPOT.TinyCore ( 4.2.0.0 ) Attaching deployed file .
Assembly: Microsoft.SPOT.Net ( 4.2.0.0 ) Attaching deployed file .
Assembly: GHI.Premium.Hardware ( 4.2.11.1 ) Attaching deployed file .
Assembly: Microsoft.SPOT.Hardware.PWM ( 4.2.0.1 ) Attaching deployed file .
Assembly: GHIElectronics.Gadgeteer.FEZSpider ( 4.2.101.0 ) Resolving .
GC : 1msec 33684 bytes used , 7305984 bytes available[/em]
Attached is a picture of my setup.
Thank you,
Andrew Paes
