When i try to debug my FEZ panda that i recently bought from Sparkfun it says “Please check your hardware”. But if i try to debug it without the FEZ Resources there is no problem. What should i do? I already tried to reinstall the firmware but it didn’t work.
In my case that’s not the problem. It turned out that this is a common error on VS2010 and GHI SDK 4.1 the solution is to make your Windows language English. I’ve done it and now it works.
Thank you.
