Debug / release
i’ve a little question about the debug function.
For debugging my project i’ve put a lot of Debug.print inside the code.
If i make a real release of my project (for my fez panda 2), are the debug.print lines sent to the board ?
Or are these line only actives when debugging ?
thanks for your help
Debug.print is not removed in release version.If you want it to be out of release you will need to use #ifdef. Search the forum we had that discussion before and there were several approaches suggested.
