hi,
I don’t know if i’m doing something wrong or if i’ve not installed the sdk right. I’ve VS2010
I start a new proyect, choose micro framework from Visual C# and then Console.Application.
The default code is very simple :
Debug.Print(
Resources.GetString(Resources.StringResources.String1));
the string1 is just the clasic Hello word!. the transport is emulator and device Microsoft Emulator. When i run it (F5), the emulator shows but it exit immediately, on the debug console no “hello wold”, it just shows this text :
Found debugger!
Resolving.
Ready.
Debug.Print(
Thread.Sleep(-1);
Debug.Print("Hello Wolrd");
Thread.Sleep(-1);
but all i get is :
Found debugger!
Resolving.
Ready.
it doesn’t work on emulator. but it works panda ii using this code :
Thread.Sleep(Timeout.Infinite); or
Thread.Sleep(-1); or other Thread.Sleep(…); variation.
this works on emulator…
PS. You can change 5000 to whatever you want… OR you don’t need to use Thread.Sleep … just look “Output window” in VS. you will see "Hello World!"
OR you have problem with your VS installation and other MF installation… i only add Thread.Sleep(-1); to your code and it worked…
best regards,
