I am attempting to create a temperature data logger that will write to an excel file on a usb flash drive. I am needing some guidance as to where to even begin with writing to a .csv file on a usb flash drive using usb host module.
Thanks in Advance
Take a look at the System.IO namespace. You need to reference System.IO.dll… There are File.Write methods there you can use
After some searches on Google, I have found some code using System.IO similar to this…
void usbHost_USBDriveConnected(UsbHost sender, GT.StorageDevice storageDevice)
stream = storageDevice.Open("tempFile\\Data.csv", FileMode.OpenOrCreate, FileAccess.ReadWrite);
writer = new StreamWriter(stream);
writer.Write("Time,Temp");
I am fairly new to c# programming and have only had a brief introduction to the System.IO class.
Any help in this area would be greatly appreciated
This should get you going… (code is not tested in real life…)
using System.Collections;
using Microsoft.SPOT.Touch;
using Gadgeteer.Networking;
using GT = Gadgeteer;
using System.IO;
using System.Text;
namespace GadgeteerApp3SdCardWriteTest
public partial class Program
// thread that does the logging
private Thread _loggerThread;
// separator used to separate all the logged elements on one line
private readonly char _separator = ';';
InitSensors();
_loggerThread = new Thread(new ThreadStart(DoLogging));
sdCard.SDCardMounted += sdCard_SDCardMounted;
sdCard.SDCardUnmounted += sdCard_SDCardUnmounted;
private void InitSensors()
// init your sensors
private void DoLogging()
// get sensor data ..
var fakeSensorData = new object[] { 1.0, 5, true, false, "GOOD", "BAD", "OFFLINE" };
var timestamp = DateTime.Now;
// log to file
WriteToFile(timestamp, fakeSensorData);
void WriteToFile(DateTime timestamp, params object[] sensorValues)
if (sdCard.IsCardInserted && sdCard.IsCardMounted)
using (var fileStream = new FileStream("data.csv", FileMode.OpenOrCreate))
var line = new StringBuilder();
line.Append(timestamp.ToUniversalTime());
for (var i = 0; i != sensorValues.Length; i++)
// add separator
line.Append(_separator);
// and sensor value
line.Append(sensorValues[i].ToString());
// add line break
line.Append('\n');
// get
byte[] data = Encoding.UTF8.GetBytes(line.ToString());
// write the data and close the file
fileStream.Write(data, 0, data.Length);
fileStream.Close();
void sdCard_SDCardUnmounted(SDCard sender)
// stop logging
_loggerThread.Start();
void sdCard_SDCardMounted(SDCard sender, GT.StorageDevice SDCard)
// start logging
_loggerThread.Suspend();
