I have 5 FEZ Cobra’s which read data from five CAN-Devices. I use five FEZs because of the processing time. I would like to send the processed data to one ChipworkX processor and then send it over the ethernet to an PC.
The problem is that I would like to have a solution in the form of an BUS structure between the FEZs and the ChipworkX. Does anyone have an solution?
I only have 3 COM-ports on the ChipworkX and have 5 FEZs. The quickest is then RS-232 and all of these components are placed on one PCB. So I will use RS-232 without lineconverts.
I can use SPI for CAN on ChipworkX, but I want to read data from 5 Devices and all of these devices have the same address. So I cannot link the different CAN devices to one interface, because I can’t see from which device i’m receiving data.
Other solution? Use outputcompare on the FEZ, but how can I receive the data on the ChipworkX. I think that polling data from the Master is to slow. I would like to send data from the slave, at any time if possible, and then let the master wait and watch five connections. But how?
What about sending data over LAN?
Why you can’t save unique address(MAC, serial or something other) to device?
If you can save unique address to each cobra you have different options. you can use CAN as GUS recommend or you can use:
chipworkX and on it connect TTL To RS485 converter and same do on each Cobra. Then you with normal Serial port class request(request include their unique serial) data from each Cobra…
Without addressing or seperate phisical connection to each device you will not know which data is from which device.
I hope that attached shematic will help you understand what Im think…
On chipworkX you connect TTL to RS485 converter to UART2(or some other UART) and open it as normal Serial Port(Read starting guide for .NETMF) on Cobra’s you do same thing. On cobra datareceived event you only respond if address equal address of Cobra…
We would like to know how the RS-485 bussystem basiclly works. We will be going to use RS-485 transceivers instead of RS-232 transceivers. But what happens if two slaves send data at the same time?
Will this be handled by the transceivers and what will take care of addressing? Do we need to this our code in the FEZ or…?
Use google how RS485 work and for protocols which you can use(MODBUS…) or make own one…
RS485 doesn’t know anything about addressing because is only electrical specification. Your cobras must respond only if address bit include their ID so it can’t happen that two device respond on same time except if two device use same ID. You can also make some global ID on which all devices respond(can be used for reboot or some other command).
Sorry it’s french but it’s an Ethernet / CAN module. I’ll see if I can find some English info’s on the thing…
I checked the Cobra and it has two CAN ports. I assume you use one to read and process your data. So you could use the other one to distribute the processed data via Ethernet either to the CWX or directly to the Computer where you want to use it.
Update: Well I found this link http://terabank.co.kr/bbshop/wiznet/eg_cn_7200.htm for an English description but I’d guess you’d still have to do a bit of direct arm programming to use it for your purpose… so I’m not sure it would be all that helpful in the end.
We are trying to setup an CAN-bus between one CWX and two FEZs. At the moment we can send data over the bus between FEZ_a and FEZ_b. We’ve implemented the CAN_RLP from tinyclr wiki on the CWX. We had some problems loading the RLP. After the first load we needed to reset and reload the firmware of the CWX.
We needed to make some adjustments to the sources to get it to run on CWX. The modified parts in RLP.h are:
[quote]// !!! The user must set these settings according to the used platform !!!
// ChipworkX #define RLP_ADDRESS 0xA0000000 #define RLP_SIZE 0x001FB3FC
We also needed to make some adjustments in the makefile, but that does not see to be relevant. After these changes we could load the RLP on the CWX without reloading the firmware everytime.
At the moment we connected an oscilloscope on the SPI lines between the MicroChip Daugtherboard and the CWX, but don’t see any data coming by. So we have some questions:
Is there a way to check if the RLP is running ok?
Did we made a mistake in connecting the Daugtheboard to the CWX?
Is there an newer version of the RLP_CAN project and can this work with the newest framework?
We found out that SPI is not working on the CWX. Is there an unknown problem that we don’t know about? SPI on FEZ is working, because we tried sending data over the Microchip PicTail Daughter board. We can’t receive data over the Daughter board, but this is another problem.
