I finally bit the bullet and decided to make my own little GPS parser.
I have not tested the code yet, as I am still working on it, but I figured in the mean time, I’d post it here to see if anyone had any suggestions on it.
So, if you have a thought, post it. I don’t care how negative it is. All criticism is good.
EDIT: For those that don’t want to read through 350 lines of code here, I also uploaded it to pastbin: http://pastebin.com/jkUJy5v2
* TinyGPS -- A very small GPS parser for NETMF
* Coded by Chris Seto 2010
* This sofware is released under the Apache 2.0 license, copyright Chris Seto 2010
* Some code derived from other sources, such as MFGps
using ChrisSeto.GeoInfoSystems.System;
using ChrisSeto.GeoInfoSystems.GeoInfoAPI;
using System.IO.Ports;
using System.Text;
namespace ChrisSeto.GeoInfoSystems.MicroGPS
/// <summary>
/// GPS fix levels
/// </summary>
public enum FixType
Void,
Active,
Unknown,
/// <summary>
/// $GPRMC Output
/// </summary>
public struct RMCOutput
$GPRMC,123519,A,4807.038,N,01131.000,E,022.4,084.4,230394,003.1,W*6A
0 1 2 3 4 5 6 7 8 9 10 11
Where:
0 RMC Recommended Minimum sentence C
1 123519 Fix taken at 12:35:19 UTC
2 A Status A=active or V=Void.
3/4 4807.038,N Latitude 48 deg 07.038' N
5/6 01131.000,E Longitude 11 deg 31.000' E
6 022.4 Speed over the ground in knots
7 084.4 Track angle in degrees True
8 230394 Date - 23rd of March 1994
9/10 003.1,W Magnetic Variation
11 *6A The checksum data, always begins with *
/// <summary>
/// Where we are going, degrees
/// </summary>
double Heading;
/// <summary>
/// How fast we are going, knots
/// </summary>
double Speed;
/// <summary>
/// Our current location
/// </summary>
Location Coords;
/// <summary>
/// Our GPS fix status, Void or Active
/// </summary>
FixType Fix;
public RMCOutput(string[] rmcParams)
// Heading
Heading = double.Parse(rmcParams[7]);
// Speed
Speed = double.Parse(rmcParams[6]);
// Coords
// Parse into degree time format
double[] lat = GPSHelper.ParseGPSDegreeTime(rmcParams[3]);
double[] lon = GPSHelper.ParseGPSDegreeTime(rmcParams[5]);
// Create the new location
Coords = new Location(GPSHelper.DegreeTmeToDegrees(lat), GPSHelper.DegreeTmeToDegrees(lon) * -1, 0);
// Fix status
switch (rmcParams[2])
case "A":
Fix = FixType.Active;
break;
case "V":
Fix = FixType.Void;
break;
default:
Fix = FixType.Unknown;
break;
/// <summary>
/// </summary>
/// <param name="rmc"></param>
public delegate void GPSUpdateDelegate(RMCOutput rmc);
public static class GPSHelper
/// <summary>
/// Parse out the concatenated degree time format the GPS returns
/// </summary>
/// <param name="from"></param>
/// <returns></returns>
public static double[] ParseGPSDegreeTime(string from)
double[] output = new double[3];
if (from.Length == 10)
output[0] = int.Parse(from.Substring(0, 2));
output[1] = int.Parse(from.Substring(2, 2));
output[2] = ToDouble(from.Substring(4, 4)) * 60;
else if (from.Length == 9)
output[0] = int.Parse(from.Substring(0, 3));
output[1] = int.Parse(from.Substring(3, 2));
output[2] = ToDouble(from.Substring(5, 4)) * 60;
return output;
/// <summary>
/// Convert degree time to degrees
/// </summary>
/// <param name="degreeTimeInput"></param>
public static double DegreeTmeToDegrees(double[] degreeTimeInput)
return (degreeTimeInput[0] + (degreeTimeInput[1] * (1 / 60)) + (degreeTimeInput[2] * (1 / 60) * (1 / 60)));
/// <summary>
/// Calculate checksum and compare
/// </summary>
/// <param name="sentence"></param>
public static bool IsValidChecksum(string sentence)
if (sentence.IndexOf('*') > -1)
string valid_checksum = sentence.Substring(sentence.IndexOf('*') + 1, 2);
sentence = sentence.Substring(1, sentence.IndexOf('*') - 1);
int checksum = 0;
for (int i = 0; i < sentence.Length; i++)
checksum ^= (int)sentence[i];
return (checksum == Convert.ToInt32(valid_checksum, 16));
return true;
/// <summary>
/// Stolen from Mark Harris
/// </summary>
/// <param name="number"></param>
public static double ToDouble(string number)
bool isNegative;
int characterPosition;
int value = 0;
int dec = 0;
int mult = 1;
if (number[0] == '-')
isNegative = true;
characterPosition = 1;
isNegative = false;
characterPosition = 0;
char c = '0';
int stringLength = number.Length;
for (; characterPosition < stringLength; characterPosition = characterPosition + 1)
c = number[characterPosition];
if (c >= '0' && c <= '9')
value = (value * 10) + (c - '0');
break;
if (characterPosition < stringLength && c == '.')
for (characterPosition = characterPosition + 1; characterPosition < stringLength; characterPosition = characterPosition + 1)
dec = (dec * 10) + (c - '0');
mult = mult * 10;
break;
float full = value + ((float)dec / mult);//(dec / (float)digits);
return isNegative ? -full : full;
/// <summary>
/// </summary>
class TinyGPS : IDisposable
/// <summary>
/// GPS
/// </summary>
private SerialPort GPSSerialHandle;
/// <summary>
/// Event to call when we have new GPS info
/// </summary>
public event GPSUpdateDelegate GPSUpdate;
/// <summary>
/// Saved up messages
/// </summary>
private string Message;
/// <summary>
/// Construct, bind the serial port
/// </summary>
/// <param name="comPort"></param>
/// <param name="baud"></param>
public TinyGPS(string comPort, int baud)
// Bind the serial port
GPSSerialHandle = new SerialPort(comPort, baud);
// Options..
GPSSerialHandle.ReadTimeout = 0;
// Flush and open the port
GPSSerialHandle.Flush();
GPSSerialHandle.Open();
// Subscribe to the data recv event
GPSSerialHandle.DataReceived += new SerialDataReceivedEventHandler(GPSSerialHandle_DataReceived);
/// <summary>
/// Handle the data
/// </summary>
/// <param name="sender"></param>
/// <param name="e"></param>
void GPSSerialHandle_DataReceived(object sender, SerialDataReceivedEventArgs e)
byte[] response = new byte[GPSSerialHandle.BytesToRead];
string fracturedMessage = String.Empty;
string[] messageQueue = new string[100];
string messageCheck;
int k = -1;
int sentenceLength = 0;
GPSSerialHandle.Read(response, 0, response.Length);
fracturedMessage = new string(UTF8Encoding.UTF8.GetChars(response));
Message += fracturedMessage;
int startIndex = Message.IndexOf("$");
int newLine = Message.IndexOf("\r\n");
if (newLine < startIndex)
Message = Message.Substring(startIndex, Message.Length - Message.Substring(0, startIndex).Length);
while (startIndex > -1 && newLine > -1)
messageCheck = Message.Substring(startIndex, newLine).Trim();
if (GPSHelper.IsValidChecksum(messageCheck))
messageQueue[++k] = messageCheck;
// Remove the message regardless...
sentenceLength = Message.Substring(startIndex, newLine).Length;
Message = Message.Substring(sentenceLength, Message.Length - sentenceLength);
newLine = (Message.Length > 3) ? Message.IndexOf("\r\n", 3) : -1;
// Iterate through the queue and parse the message
for (int i = 0; i < 100; i++)
if (messageQueue[i] != null && messageQueue[i] != String.Empty)
string[] splitSentence = messageQueue[i].Split(',');
if (splitSentence[0] == "$GPRMC")
GPSUpdate(new RMCOutput(splitSentence));
messageQueue[i] = null;
break;
