I just posted Temp4710 on Creations. Feel free to discuss and make suggestions here.
@ dominik38 - I really like the configurable address via jumpers. Would be very useful in a situation where you need to monitor multiple temperature zones. Keep up the good work!
Thanks!
Yes you are right, sometimes it’s neccessary to measure the temperature at more than one point. I’ll post an image of the back side soon (and also a better one of the front :wall: )
Is the temperature measurement accurate? Can you tell us the chip you have used?
The clue is in the Module name. Analog Devices ADT7410. http://www.analog.com/static/imported-files/data_sheets/ADT7410.pdf
Yes, scardinale is right, chip is ADT7410, accuracy is ±0.5°C.
