why is it when you define an outputport and inputport you type
OutputPort((Cpu.Pin)FEZ_Pin.AnalogOut
and not
OutputPort(FEZ_Pin.AnalogOut
ex in the manual it shows the top example and the range finder example code shows the lower one?
and not
You can take a look here
By default the underlying type of each element in the enum is int
But you don’t want the integer representation , you need the Pin name. So you have to cast to the right type here to Cpu.Pin
is the correct usage. The other is maybe a typo or you didn’t have the newest release of the ebook
If you are using the “USBizi pin definitions” then you do not need to cast. We changed the type on FEZ to make the drivers easier for beginners. Also, not all USBizi pins are available on FEZ.
It is a long story but anyway we had reasons to change the type, and so, you need to cast to use.
