I have a Cobra 2 with a CP7 attached on a machine.
We machined out a metal enclosure and installed it with double sided tape on the edge of the CP7.
The touch events on the 2 buttons i have on the screen are not firing all the time. Actually the buttons don’t even look like they are being pressed on the screen
I have the standard cables connected and am using an external power supply.
i setup the event with
Tried it with a new display as the other is rtv’ed in the hole but same results.
it worked intermittently last week but now doesn’t work at all.
i even tried with the Power Extender Module but same results.
any guesses?
I am in a room with fluorescent lights. I am using Skewworks tinkr2.
at our plant all of our lights are fluorescent light.
is there something i can do to fix this like grounding the display case or something like that or am i out of luck?
do the Display T43 Module have the same problem with fluorescent lights?
these links discuss noise, the two most common problems being power supplies and fluorescent lights; I didn’t read them through, but some of them may discuss shielding (?).
