I am loading a Bitmap from a SD card & displaying it as a background on the CP7. As long as I draw circles, text ect, I don’t have any issues. As soon as I load in a bmp / jpeg, I get a flickering on the screen.
I loaded in a series of test patterns, (ie a series of lines, first 1 pixel apart, then 2 pixels, then 3 pixels). The vertical lines on first glance don’t show any sign of the flicker. The horizontal ones however did, with the lines 1 pixel apart showing the worst, and gradually showing less as the pixels got further apart.
The conclusion that I reached is that the bitmap is shifting up and down 1 pixel rapidly, a guestimate being 50hz?. (The vertical lines do show a slight flicker at both the top & bottom).
I tried to load in smaller images, (and different formats), and have the issue as long as I use the display image command.
If it was an LCD config issue, why does the display text or display ellipse not show the same issues?
Private Sub sdCard_SDCardMounted(sender As SDCard, SDCard As Gadgeteer.StorageDevice) Handles sdCard.SDCardMounted
displayCP7.SimpleGraphics.DisplayText("test", Resources.GetFont(Resources.FontResources.NinaB), GT.Color.Red, 350, 250)
imgBackground1 = SDCard.LoadBitmap("300x200.jpg", Bitmap.BitmapImageType.Jpeg)
imgBackground2 = SDCard.LoadBitmap("300x200b.jpg", Bitmap.BitmapImageType.Jpeg)
imgBackground3 = SDCard.LoadBitmap("300x200c.jpg", Bitmap.BitmapImageType.Jpeg)
imgBackground4 = SDCard.LoadBitmap("300x200d.jpg", Bitmap.BitmapImageType.Jpeg)
displayCP7.SimpleGraphics.DisplayImage(imgBackground1, 0, 0)
displayCP7.SimpleGraphics.DisplayImage(imgBackground2, 300, 0)
displayCP7.SimpleGraphics.DisplayImage(imgBackground3, 0, 200)
displayCP7.SimpleGraphics.DisplayImage(imgBackground4, 300, 200)
' newCard = SDCard
End Sub
