Firstly… thank you for releasing Gadgeteer Package 2013 R2.
I just installed in and had a quick attempt to use it with the G400HDR. However, I noticed a couple of issues. (Note sure if all are bugs or this way by design):
- In the Toolbox for Seeed there are two GSM modules.
- One of the two GSM modules look a bit strange. (No connector to click on and the graphic looks a bit squashed up). The other one looks ok, but clicking on its connector does not allow me to connect to any of the G400HDR sockets.
3.It is impossible to add the Ethernet ENC28 module. (complains about library not found) - When you click on the connector of the SD card it does not show that you can connect it to any of the sockets of the G400HDR.
I would appreciate to hear if these are bugs or expected behaviour.
