Hi all !
I want to use the counter for measurement of the frequency before 1MHz.
Prompt as this better do.
@ rpis - Look at SignalCapture class in the GHI.IO namespace documentation.
I test this method. result - measured frequency before 40 kHz only
I use NETMF 4.2
This is an option
https://www.ghielectronics.com/catalog/product/465
I want use Register class for Timer/Counter from processor. But shall be able I measure frequency 1 MHZ ?
Then the datasheet of the processor is your best option. You can use the register class or RLP to access the processor directly.
I try RLP but why my code not work - interruption does not occur?
#include "lpc17xx_timer.h"
#include "lpc17xx_libcfg.h"
#include "lpc17xx_pinsel.h"
#include "RLP.h"
#define STATUS_SUCCESS 0
#define STATUS_ISR_INSTALL_FAILED -1
#define STATUS_OUT_OF_MEMORY -2
#define STATUS_MUST_WAIT -3
#define STATUS_INVALID_ARG_COUNT -4
#define STATUS_INVALID_FORMAT -5
PINSEL_CFG_Type PinCfg;
TIM_TIMERCFG_Type TIM_ConfigStruct;
TIM_CAPTURECFG_Type TIM_CaptureConfigStruct;
uint32_t capture=0;
BOOL_8 IsrInstalled = FALSE;
void TimerIsr(void *arg)
if (TIM_GetIntCaptureStatus(LPC_TIM2,0))
TIM_ClearIntCapturePending(LPC_TIM2,0);
RLPext->PostManagedEvent(LPC_TIM2->CR0);
capture = TIM_GetCaptureValue(LPC_TIM2,0);
TIM_Cmd(LPC_TIM2,DISABLE);
TIM_ResetCounter(LPC_TIM2);
TIM_Cmd(LPC_TIM2,ENABLE);
int InitMeasureFreq(void *generalArray, void **args, unsigned int argsCount, unsigned int *argSize)
//Config P0.4 as CAP2.0
PinCfg.Funcnum = 3;
PinCfg.OpenDrain = 0;
PinCfg.Pinmode = 0;
PinCfg.Portnum = 0;
PinCfg.Pinnum = 4;
PINSEL_ConfigPin(&PinCfg);
// Initialize timer2, prescale count time of 100000uS
TIM_ConfigStruct.PrescaleOption = TIM_PRESCALE_USVAL;
TIM_ConfigStruct.PrescaleValue = 100000; //100mS
// use channel 0, CAPn.0
TIM_CaptureConfigStruct.CaptureChannel = 0;
// Enable capture on CAPn.0 rising edge
TIM_CaptureConfigStruct.RisingEdge = ENABLE;
// Enable capture on CAPn.0 falling edge
TIM_CaptureConfigStruct.FallingEdge = DISABLE;
// Generate capture interrupt
TIM_CaptureConfigStruct.IntOnCaption = ENABLE;
// Set configuration for Tim_config and Tim_MatchConfig
TIM_Init(LPC_TIM2,TIM_TIMER_MODE,&TIM_ConfigStruct);
TIM_ConfigCapture(LPC_TIM2, &TIM_CaptureConfigStruct);
// Hook our interrupt handlers
if (!RLPext->Interrupt.Install(TIMER2_IRQn, TimerIsr, NULL)) return STATUS_ISR_INSTALL_FAILED;
IsrInstalled = TRUE;
// To start timer2
RLPext->Interrupt.Enable(TIMER2_IRQn);
RLPext->PostManagedEvent(111);
return STATUS_SUCCESS;
int DeinitMeasureFreq(void *generalArray, void **args, unsigned int argsCount, unsigned int *argSize)
if (IsrInstalled)
RLPext->Interrupt.Uninstall(TIMER2_IRQn);
TIM_DeInit(LPC_TIM2);
int QueryFreq(unsigned long *generalArray, void **args, unsigned int argsCount, unsigned int *argSize)
RLPext->Interrupt.Disable(TIMER2_IRQn);
generalArray[0] = capture;
anyone can say where I mistaken?
