I have a function that I am using with a USB host raw device:
public static int GetProtocol(USBH_RawDevice openedDevice)
var dataBytes = new byte[2];
openedDevice.SendSetupTransfer(
(byte)(UsbRequestType.DeviceToHost | UsbRequestType.Vendor),
(byte)AndroidAccessoryUsbCommands.GetProtocol,
0,
1,
dataBytes,
0,
dataBytes.Length
return (dataBytes[1] << 8) | dataBytes[0];
This is part of the Android Open Accessory handshaking. The gist of it is that if you have a device that speaks the Android Open Accessory protocol, it will respoond to this request with a version number. Which works great for devices that support the protocol.
However, if you plug in a device that does not speak the protocol, I get an exception:
#### Exception System.Exception - 0xffffffff (1) ####
#### Message:
#### GHIElectronics.NETMF.USBHost.USBH_RawDevice::SendSetupTransfer [IP: 0000] ####
#### Prototype.AndroidOpenAccessory.Fez.AndroidAccessoryUtil::GetProtocol [IP: 0018] ####
#### Prototype.AndroidOpenAccessory.Fez.HelloFez.Program::Main [IP: 008f] ####
A first chance exception of type ‘System.Exception’ occurred in GHIElectronics.NETMF.USBHost.dll
An unhandled exception of type ‘System.Exception’ occurred in GHIElectronics.NETMF.USBHost.dll
No InnerException. Message is “Exception was thrown: System.Exception”. There looks like there is a non-public m_HResult = 4294967295 but that’s just the 0xffffffff value and not useful (and I can’t access it anyway due to its protection level).
Now, I can appreciate that an Exception is used to signal the fact that the device balked at the command that was sent. But I can’t differentiate between “this device did not respond to the USB command that was sent” and “something has seriously gone wrong”.
Am I missing something? It seems like a specialized UsbException with some more actionable details would be useful.
