Someone can help me converting a string like that 02:00:30:01:00:07 to a byte.
Because I have to setup mac address reading value from an SD card and pushing it on network interface.
Tried something like that
MAC[0] = Byte.Parse(corrected_mac.Substring(1, 2));
MAC[1] = Byte.Parse(corrected_mac.Substring(3, 2));
MAC[2] = Byte.Parse(corrected_mac.Substring(5, 2));
MAC[3] = Byte.Parse(corrected_mac.Substring(7, 2));
MAC[4] = Byte.Parse(corrected_mac.Substring(9, 2));
MAC[5] = Byte.Parse(corrected_mac.Substring(11, 2));
but it doesn’t work.
Ideas??
Tks
MAC[0] = (byte)Byte.Parse(corrected_mac.Substring(0, 2));
MAC[1] = (byte)Byte.Parse(corrected_mac.Substring(2, 2));
MAC[2] = (byte)Byte.Parse(corrected_mac.Substring(4, 2));
MAC[3] = (byte)Byte.Parse(corrected_mac.Substring(6, 2));
MAC[4] = (byte)Byte.Parse(corrected_mac.Substring(8, 2));
MAC[5] = (byte)Byte.Parse(corrected_mac.Substring(10, 2));
I found that solution not so look good, but it works
Mike
February 25, 2018, 3:31pm
#4
your solution will not work all the time. It fails with a hex number, which can appear in MAC.
Google “c# hex string to byte” or look at the byte.parse documentation for the number type parameter.
Ok tested and updated with code on google.
now it’s better.
Tks
You can try this class.
Usage:
byte[] _mac = StringToHex.FromString(corrected_mac);
public static class StringToHex {
public static byte[] FromString(string value) {
string[] _peices = value.Split(':');
byte[] _mac = new byte[6];
for (int i = 0; i < _mac.Length; i++) {
_mac[i] = Oclet(_peices[i]);
return _mac;
private static byte Oclet(string hexValue) {
byte _hexResult = 0x00;
hexValue = hexValue.ToUpper();
char[] _values = hexValue.ToCharArray();
for (int i = 0; i < _values.Length; i++) {
_hexResult *=16;
if (_values[i] <= (byte)('9') && _values[i] >= (byte)('0')) {
_hexResult += (byte)(((byte)_values[i]) - (byte)('0'));
else if (_values[i] <= (byte)('F') && _values[i] >= (byte)('A')) {
_hexResult += (byte)((byte)_values[i] - (byte)('A') + 10);
else {
throw new ArgumentException("Specified value is out of range");
return _hexResult;
