I am having an error trying to convert a double number to an integer. I’ve dug around on the forums and some general C# forums but can’t seem to solve the issue. Any help?
double stepspermm; //calculate how many steps are required to travel one mm with syringe
int stepspermmint; //convert the calculated steps into an integer value
stepspermm = (((degperrev/Syringe_Motor_Angle)*halfstepmult)*Lead_Pitch);
stepspermmint = Convert.ToInt32(System.Math.Round(stepspermm));
Error List:
Error 1 The best overloaded method match for ‘System.Convert.ToInt32(string)’ has some invalid arguments C:\Users\JShubert\documents\visual studio 2010\Projects\SlaveUnit\SlaveUnit\Program.cs 72 29 SlaveUnit
Error 2 Argument 1: cannot convert from ‘double’ to ‘string’ C:\Users\JShubert\documents\visual studio 2010\Projects\SlaveUnit\SlaveUnit\Program.cs 72 45 SlaveUnit
Do I need to convert the double to a string then the converted string to an int? That seems silly but appears it will work. I’d like a more elegant solution. Appreciate anyone’s help on this.
