I know this is probably super simple but I am struggling ( I swear I have figured this out once before).
Tried scouring APIs and google.
For some reason the code goes into in infinite loop of nothingness when I do:
string buffer = BitConverter.ToString(buffer,0)
nevermind I finally found my old code:
char[] temp = Encoding.UFT8.GetChars(buffer);
string received = new string(temp);
Visual basic has many great string utilities. Another option is to create a class library an call the high level functions from your code.
Example:
'Convert the byte to string
Return ChrW(Data(0)).ToString
C sharp class libraries can be used in vb and vb libraries can be used in C sharp. I think each language has its strong points and weak points
Do not forget the
Standard Numeric Format Strings
