Hi guys,
I know that this might be something basic but I can’t find any working solution. I have a byte value that I need converted into hexadecimal.
Could you please point me in the right direction ?
Hi guys,
We have some codeshare entries for that.
Here is one of them:
https://www.ghielectronics.com/community/codeshare/entry/46
Been there, tried that and I got this:
The name ‘hex’ does not exist in the current context
and couldn’t find the right solution … I’m afraid some things just elude me.
LE: works better if I copy everything :))
Thanks, problem solved !
Like this?
Dim b As Byte = 100
Debug.Print(b.ToString("X2"))
Btw, that codeshare is working for me.
@ iamin - Right. Forgot about it.
Custom solution is for old version of NETMF. “X2” is supported now.
And I found a bug…
Any value from 128 to 255 including is not correctly shown when ToString(“X2”) is used.
@ iamin - are you sure ? 193 got me C1 which seems alright …
I am getting FFFFFFC1. With every value above 128 I get added those FFFFFF.
Can anyone confirm?
Tried these two:
static readonly string hex = "0123456789ABCDEF";
/// <summary>
/// Converts Byte to a Hexadecimal string, like .ToString("X2") would do;
/// </summary>
/// <param name="number">Byte to represent has a hexadecimal string.</param>
/// <returns>2 character string of hexadecimal representation of the number</returns>
public static string FromByteToHex(byte number)
return new string(new char[] { hex[(number & 0xF0) >> 4], hex[number & 0x0F] });
string s = FromByteToHex(193);
string f = 193.ToString("X2");
Works both ways in emulator
:think:
Can you try this:
byte b = 193;
Debug.Print(f);
Debug.Print(b.ToString("X2"));
I am getting:
[quote]C1
FFFFFFC1[/quote]
Yep, confirmed.
I was going to report this bug, but apparently somebody did it already. Let’s hope MS addresses all these small bugs in the near future.
This was the fix that I ended up using: (math.abs())
Debug.Print(Resources.GetString(Resources.StringResources.String1));
Byte b=193;
Debug.Print(f);
Debug.Print(System.Math.Abs(b).ToString("X2"));
‘Microsoft.SPOT.Emulator.Sample.SampleEmulator.exe’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\mscorlib.dll’, Symbols loaded.
‘Microsoft.SPOT.Emulator.Sample.SampleEmulator.exe’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Native.dll’, Symbols loaded.
‘Microsoft.SPOT.Emulator.Sample.SampleEmulator.exe’ (Managed): Loaded ‘c:\users\mike\documents\visual studio 2013\Projects\MFConsoleApplication1\MFConsoleApplication1\bin\Debug\le\MFConsoleApplication1.exe’, Symbols loaded.
Hello World!
C1
C1
@ mtylerjr - That is working because Math.Abs is promoting the byte to an int. You could also just cast the byte to an int which is a native IL op code and will not incur the cost of the function call overhead which is significant in .NETMF.
Debug.Print((int)b).ToString("X2"));
Well then. This is why I claimed you were a genius. Of course just casting it to int is better!
Thank you, but I can assure you I am no genius. Not even close, just ask my wife.
