I was bored, so I decided to see how easy it was to control a servo with my USB joystick.
Here is the code:
using GHIElectronics.NETMF.USBHost;
using System.IO;
namespace Servo
public static PWM servo = new PWM((PWM.Pin)FEZ_Pin.PWM.Di8);
public static USBH_Joystick joystick;
public static bool servoDisabled = false;
public static int invert = -1;
USBHostController.DeviceConnectedEvent += joyConnected;
public static long map(long x, long in_min, long in_max, long out_min, long out_max)
return (x - in_min) * (out_max - out_min) / (in_max - in_min) + out_min;
public static void joyConnected(USBH_Device device)
if (device.TYPE == USBH_DeviceType.Joystick)
Debug.Print("Joystick connected...");
joystick = new USBH_Joystick(device);
joystick.JoystickXYMove += moveServo;
joystick.JoystickButtonDown += checkButton;
public static void moveServo(USBH_Joystick sender, USBH_JoystickEventArgs args)
if (!servoDisabled)
servo.SetPulse(20 * 1000 * 1000, (uint)map(sender.Cursor.X * invert, -512, 512, 410, 2140) * 1000); //410, 2140 OLD: 150, 2400
public static void checkButton(USBH_Joystick sender, USBH_JoystickEventArgs args)
switch (args.ChangedButton)
// Lock servo
case 2:
servoDisabled = true; ;
break;
// Disengage the servo
case 3:
servo.Set(false);
break;
// Enable the servo
case 1:
long time = map(sender.Cursor.X * invert, -512, 512, 150, 2400);
servo.SetPulse(20 * 1000 * 1000, (uint)time * 1000);
break;
// Toggle joystick orentation
case 5:
invert *= -1;
break;
case 4:
invert *= -1;
servo.SetPulse(20 * 1000 * 1000, (uint)map(sender.Cursor.X * invert, -512, 512, 150, 2400) * 1000);
break;
The code may be a little messy (and not very DRY), but it works extremely well.
It’s worth noting that I never found a good diagram listing how the PWM pulse relates to the angle of the control arm’s movement . In the end, I had to use my O-Scope to figure out that 0 degrees is .41ms, center is 1.269ms and 180 is 2.141ms.
Imagine i take the servo to a certain position and it can stay there for a while. I have a thread that normally updates the servo position. pseudo code
thread servoposition
while(true)
calculate newposition
if (oldposition != newposition)
enable servo
goto new position
disable servo
in fact I want the servo to stay in its position (there is no external force acting on the servo) like removing the control wire from the board. So the servo stays at its old position without continously being updated.
If you use my class to assign the servo to a position it will stay in that position as the PWM hardware will maintain the proper wave. No updating is required.
I know that the servo keeps it position by the pwm signal. But I want to switch off the pwm towards the servo. Meaning the servo stays in the last position when switched off (no pwm signal).
I am using the servo to control butterfly valves that needs a position update maybe 1 time per hour.
The reason to switch them off is the noise they make when the pwm is fed into the servo.
I have to say these servos are rather old.
@ PEETEPEETE: The servos you are using will maintain their last position when they loose the command signal? Or do you remove power from the servo so the command signal becomes irrelevant?
If you just want to remove the PWM command signal you could dispose the PWM object for that pin and make it an output pin set to HI or LOW. I have not played with the PWM on the FEZ so I’m not sure if it is possible to specify the output signal have a 0% or 100% duty cycle which would be the same thing as having the pine set to an output and set LOW or HI.
Everything works like a charm no more buzzing. This is the small junk that does it.
if (positionold != position)
rcservo.SetPulse(20 * 1000 * 1000, position * 1000);
positionold = position;
rcservo.Set(true); //This switches of the pwm to the servo.
I havent try Chris new driver yet, but I notice that those existing drivers when I set it to sweep left to right some thing like this code would cause the servo to continue going some extra miles instead of immediately stop at 0 or 180 degree. It seems that the servo continue to go to -20,190 degree respectively. Does this driver address that issue?
for (int i=0;i<=180; i++)
servo.setposition(i);
sleep(sometime);
to prevent breaking my servo, I usually have to do some this like from 45 - 165, etc.
Thanks!
Make sure to set the timings to 1000 and 2000.Otherwise, the servo should never hunt for a position, unless it’s a result of the PWM bug that was fixed a long time ago.
As a long time c# coder (and MVP), I would only suggest some .net naming conventions as it really helps readability and makes things more ez. Camel case normal. All method names (private, public or static) start with upper case. private vars lower, public vars and properties upper. Sounds like a nit, but is really more important that it sounds as it also expresses intent and help communicate. Thanks for the code. Would this work with Mini?
As far as naming standards go, this was like my first driver, cut me some slack I am a professional dev, and most of my recent NETMF reflects that. This particular drive may have been a little rough while I adjusted to VS.
Hey Chris. No worries. Thanks again for your work I was trying to be more general. I have noted this same issue with many codes here. If we don’t talk about it, nobody learns. Myself, on the HW end, have much more to learn. Keep up the good work!
