We typically Dispose of our CAN ports when the CANBUS is stopped (ie, vehicle turned off). When attempting to do so with the ControllerAreaNetwork object in 2014 R5 the microcontroller (G120) crashes hard. It disappears from USB device list on my laptop and then several minutes later it reboots itself. the following code is an easy demo of this problem. The LED stops flashing the moment the can.Dispose() method is called.
Can anyone explain? Thanks.
namespace CAN_TEST
private static GHI.IO.ControllerAreaNetwork can;
static OutputPort led;
led = new OutputPort(GHI.Pins.G120.P1_15, false);
new Thread(() =>
led.Write(!led.Read());
Thread.Sleep(250);
}).Start();
can = new GHI.IO.ControllerAreaNetwork(GHI.IO.ControllerAreaNetwork.Channel.One, GHI.IO.ControllerAreaNetwork.Speed.Kbps250);
can.ErrorReceived += can_ErrorReceived;
can.Enabled = true;
Thread.Sleep(10000);
can.Enabled = false;
can.Dispose(); ///Problem HERE!
static void can_ErrorReceived(GHI.IO.ControllerAreaNetwork sender, GHI.IO.ControllerAreaNetwork.ErrorReceivedEventArgs e)
Debug.Print(e.Error.ToString());
