Anyone has an idea of which controller or LCD panel is used on the http://www.ghielectronics.com/catalog/product/240 ?
I’m trying to find the datasheet of the controller so I can compare signal diagrams with other LCD controllers.
I think they’re a pretty basic panel, and the controller is all handled in the EMX; I have the 4.3" so can’t tell you what panel the 3.5" uses, but the 4.3 is the LQ043T1DG01, which from memory was used in many 4.3" GPSes (check ebay)
Thanks Brett for the typenr. I typed ‘controller’ but I ment ‘driver IC’. Anyway, the datasheet of the LQ043T1DG01 contains signal information, which is what I’m interested in.
Just want to see how much configuration work I’ll have in order to connect a custom TFT LCD panel.
