Made a few bug fixes and cleaned up the code a lot. http://files.chrisseto.com/1e8
The only problem I’m having with it is that it is really slllooowww…
Wow :o Thank you Chris, I will give it a try.
Do you still have the large html file? I can get it working since I have the packet limit problem fixed.
Yep, I did back it up for just such an occasion.
Note that it also includes a large header background image. I’m not sure if that is too big to use on the Domino. The image is ~70K as a PNG file, but NETMF doesn’t like PNG so it’s ALOT bigger as a BMP.
That said, I might also look at building the HTML down smaller than I did. The JS is already compressed, I could also try stripping the whitespace from the HTML.
BTW I tried to have some images on a webserver before.
This image is GIF. but I had to cheat on Visual studio by changing the file type to an unknown type like “gif_f” This way I force Visual studio to consider it as a binary resource, Not an image.
In a web server you don’t need your system to consider it as an image. so you png file would work fine too.
Can I have the file with the bigger html file. I will try it here.
Yeah, give me a sec. I have to wake on lan my desktop then remote in. I’ll email it to you.
Great! Thanks Chris
Yep, no problem!
Let me know if you’re able to get the big page to work.
