From what I have seen, it’s down to the costs of the Wireless module. The manufacturer has to get certification and I hear that this is expensive.
I got quoted recently for a WCDMA device from Simcom and in 100 off quantities, the module was $33. By the time you add the board and the other support components, you can start to see why a module like this is expensive.
Just seems like when you can buy a no-contract phone for $20, which includes quad-band EDGE and dual-band HSDPA, and a screen, keypad, case, speaker, mic, etc, etc, etc, that you should be able to get just the radio guts for significantly cheaper than even $33…
@ godefroi - That’s probably a matter of scale. Those $20 phones are produced in very large quantities, so the manufacturer can get a significant discount.
Modules in small quantities for micro projects will always be significantly more expensive.
Also, phone manufacturers are not using modules, they are using the IC’s form within a module to build it and as Devhammer says, they are purchasing in the hundreds of thousands. Look at a simple IC for example. $5 in 1 off and < $1 when you buy 1000.
And, of course, the other piece that I missed mentioning is that even $20 phones are likely somewhat subsidized, at least here in the US, as the seller either gets a subsidy from the carrier, or the carrier directly sells the phone and provides some of the anticipated revenue from services sold (prepaid or contract) to offset the up-front cost of the hardware.
This module seems interesting. Dave is waiting for the Seeed cell module to arrive, and I am expecting his brilliance to be successfull.
But the Seeed module is old, and there is arguments for maybe considering other more efficient paths…
The SparQee project got funded, and I had a dialogue with one of the designers behind the board and asked for the amount of AT commands required. Beause I am seriously concerned about the complexity of the driver.
What we need is a standard TCP/IP connection over mobile radio.
I asked: “Can you show how simple the module is to use?”
His reply is here:
Well, I do it with 2 commands for a text and 5 for data (complete session), so no, there's not lots of AT commands.
Here's a text example:
at+cmgf=1
at+cmgs="+18557727785"
> hey there
Here's an example of a full session for sending data:
at+zipcall=1
at+zipopen=1,0,www.testUrl.com,9999
at+zipsend=1
at+zipcall=0
Here's the full text of the transaction:
at+zipcall=1
OK
+ZIPCALL: 1, 10.233.156.132
at+zipopen=1,0,www.textUrl.com,9999
OK
+ZIPSTAT: 1, 1
at+zipsend=1,
OK
+ZIPSEND: 1, 15
+ZIPSTAT: 1, 0
at+zipcall=0
OK
+ZIPCALL: 0, 0.0.0.0
