I’ve used a Hyrda at the default IP address without any problems for a long period of time. I needed to change the IP address so I thought it would also be a good time to update the driver/firmware. The installations worked fine and the firmware update did as well.
I’ve used FEZ_Config_v011 to change the IP address. I ping it at the new address and it responds as expected. I’m using the same code on the Hydra pre-update that I’ve been running without any problems at the default IP address for a long period of time. Pre-update, I could connect and disconnect to it with a desktop piece of software without any problems. However, now it works for a while and then the network connection drops. After this happens it doesn’t respond when I try to ping it. It just says that the request times out.
When I reset the Hydra, I can go back to pinging it without any problems. I have to have a stable network connection to the device for the application to work.
Any ideas on what might be causing the network connection to drop and what steps to take to correct it?
I’ve tried connecting through a switch and connecting direct and it behaves the same.
