Also, are there any really good examples on how to read/write single registers via SPI in this
forum,
All I need to do is simple 8 bit writes / reads…
Thanks, I have seen that example, and am still not sure I am doing my writes correctly.
at the bottom is a bit example code provided by the spi device mfg(NXP SC16IS75X),
for talking with the device via a 8051 mcu,
Here is an example of how I am trying to write a 0x80 to the LCR register,
is this correct, , can I do it via one call to the write routine using a 2 byte buffer?,
…etc,
Thanks for any help / insight you can provide,
char SPI_send (char byte) { // mcu sends a byte to spi bus
SPDAT = byte; // data is sent
while(!SPI_tx_completed); // wait end of transmission
SPSTAT &= ~0x80; // clear mcu spi interrupt flag (SPIF)
SPI_tx_completed = 0; // clear transmit spi interrupt flag
return SPDAT; // receive data on spi read
char SPI_read (char register) { // mcu reads a register from SC16IS750
SPI_SS = 0; // enable slave chip select
SPI_send((register<<3) | 0x80); // register address is sent
register = SPI_send(0); // dummy data is sent for spi read
SPI_SS = 1; // disable slave chip select
return register; // receive the read data
void SPI_write (char address, char data) { // mcu writes data to SC16IS750
SPI_send (address<<3); // address is sent
SPI_send (data); // data is sent
Please ignore my question below about the writes , I dug into the forum and found
the answer, – I should just use a single call to write with a buffer that contains
the addr / data…
if you have any other insights thought or any other specific example please send my way.
The “code” tags (the 101010 icon in a reply) formats your text as code, please use it (modify your existing post to set that too)
I know nothing about your chip.
SPI write two bytes needs you to do two things. Create a two-byte array with your data, and do one write.
byte[] tx_data = new byte[2];
tx_data[0] = NXP_Comm.LCR <<3; // why does it shift 3 bits ?
tx_data[1] = 0x80;
MySPI.Write(tx_data);
That should write the register address and 0x80, assuming you have NXP_Comm.LCR set right. You should explicitly check what value that should be from a datasheet.
edit: I see you’ve added a new post while I was typing
