Hello,
Is there any way to erase data in PermanentUserKey on FEZ Domino board? Any technical trick?
I didn’t think there was any permanent data… I don’t have a Domino just Panda’s… and they don’t
Cheers Ian
There is [quote]GHIElectronics.NETMF.Hardware.Configuration.PermanentUserKey[/quote] parameter. On Domino board it’s 16 byte
Hello Alagrat,
it is described in the GHI SDK documentation
BR
Marc
Yes, i know it… Thats why asked this question. Not only software, may be any hardware solution.
Then it wouldn’t be “permanent” if there is a ways
OK ;D Thanks a lot!
I suppose you could peel the top off the chip, get an electron microscope and somehow do some bit twiddling.
Rrright! ;D
