Nope
STM on a lasagna noodle?
@ FireyFate - fairly close
@ Justin - Ok, enough teasing. Post a pic! ;D
Hmmm, are we finally getting a flexible wearable NETMF?
@ Architect - no can do, will spoil the naming competition
@ FireyFate - nope, the heat build up would cause burns :whistle:
@ Justin - ~!@ #@ #%E
Should not have said anything to begin with! ;D
@ Justin - I am going to call you Gustin from now on.
I wasn’t suggesting it should attach directly to the skin!
@ Architect - bit of Gus 101 to build the suspense
I have not teased anyone in a while :whistle:
Haha Justin you tease!
I think i have designed the Ultimate g120 board…2 years in development(well, part time).
@ anthonys - details please
It has xbee forms factor sockets, g120, ethernet, sdcard, arduino shield socket, 8 relays, 8 opto-inputs, 8 adc inputs, 1wire interface, CAN interface, can use serial or SPI display and every pin is exposed for what you like to do.
It has many components but have designed so you just don’t solder what you will not use BUT i love the board because i can get things done without worrying about hardware addons etc which take time and if you have limited knowledge of electronics, can be a show killer.
@ anthonys - Image or it does not exists
Make it compatible with the TRS-80 thermal printer.
Here is the PCB design
@ mtylerjr - Why thermal printer, what do you envisage using it for?
