Combination of FEZ Domino, RS232 Shield, LCD & Keypad Shield
before i order the fez domino and the RS232 shield + LCD Shield i want to now, if i can combine the shields.
I think the rs232 uses pins Di0 & Di1 and the LCD uses Di4 to Di9. So i can use the both shields paralell. Is that right?
What pins are used by the Ethernet Shield? I did not find any information about this in the brochure.
Best Regards,
Arne
We modified the description of each shield to list what pins are used.
You are correct, the RS232 shield can be combined with LCD&Keypad shield.
